Date/Time: Wed, 12 Mar 2025 11:49:11 +0000
Trade Activity Log - If To: Today is checked the date is useless
View Count: 452
[2022-05-11 08:53:43] |
User569373 - Posts: 27 |
Hello As the title says: Trade Activity Log - If To: Today is checked the date is useless -> Consult the picture. Kind Regards |
[2022-05-11 12:01:11] |
When the Today option is checked, the To Date is not used and is disabled. In this case, all of the trade activity data from the From Date-Time up until what is available in the files is used.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-11 12:01:32
[2022-05-13 09:12:40] |
Instead displaying an invalid date “294177-01-07” it would make sense to display the real date of “Today” when it is checked. There is now reason to display an invalid date. It’s only a source of concern.
[2022-05-13 12:02:21] |
That is not an invalid date. That is an actual correct date and that is the actual date which is used.
