Date/Time: Fri, 14 Mar 2025 22:29:05 +0000
I am unable to find the source code for the DOM chart
View Count: 808
[2022-05-11 00:14:14] |
VerySherri - Posts: 3 |
I really just need to see how the pulls and stacks are calculated and summed at the top and bottoms of the columns. But, knowing how to find the source code for these kinds of questions would be very helpful. Thank you |
[2022-05-11 14:59:21] |
ForgivingComputers.com - Posts: 1028 |
How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available
[2022-05-11 19:06:45] |
JohnR - User831573 - Posts: 320 |
If you look in studies.cpp inside of \SierraChart\ACS_Source\Studies.cpp, there is some source that might be what you are looking for. /*==========================================================================*/ SCSFExport scsf_DepthOfMarketData(SCStudyInterfaceRef sc) //scsf_DOMAccess { SCSubgraphRef Subgraph_BidSize = sc.Subgraph[0]; SCSubgraphRef Subgraph_BidValue = sc.Subgraph[1]; SCSubgraphRef Subgraph_AskSize = sc.Subgraph[2]; SCSubgraphRef Subgraph_AskValue = sc.Subgraph[3]; SCSubgraphRef Subgraph_BidStackPullValue = sc.Subgraph[4]; SCSubgraphRef Subgraph_AskStackPullValue = sc.Subgraph[5]; Hope this helps, JohnR |
[2022-06-15 09:24:19] |
There is no source code for this. However, these market data columns are fully documented here: Global Trade Settings Windows: Bid Market Depth Pulling/Stacking - Left/Center/Right Aligned Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-15 09:24:27
[2022-07-06 14:35:16] |
Is there documentation for the DOM API? I would like to have programmatic access to the stack/pull values of the DOM study and I'm not sure where to access that data. Do I need to access the data feed directly and recalculate the pull/stack data? I don't want to overcomplicate it.
[2022-07-06 17:57:17] |
John - SC Support - Posts: 38678 |
You would access the information you need using the functions outlined at the following link and the section after it: ACSIL Interface Members - Functions: sc.GetBidMarketDepthStackPullSum() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
