Date/Time: Wed, 12 Mar 2025 11:55:58 +0000
Reinstalled Sierra charts can't view old trade fills
View Count: 466
[2022-05-10 19:27:32]
User332567 - Posts: 5
On 6th May 2022 I had some error with my operating system, I reinstalled the OS on my desktop and after that installed the Sierra chart platform. Now I'm not sure if I can view the older fills (trading log) after reinstalling the O/S, is there a way I can view my old trading fills(trading log) or have I completely lost the old trading log, after reinstalling the O/S and Sierra chart. Thank you!
[2022-05-11 14:10:24]
John - SC Support - Posts: 38598
If you did not manually copy or move the Trade Activity Logs from the prior installation, then that information is no longer available.
Refer to the information in Step #5 of the following section for information on the Sierra Chart files and where they are located:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
