Date/Time: Wed, 12 Mar 2025 11:38:06 +0000
Show only buy orders or sell orders on chart
View Count: 693
[2022-05-10 18:20:20]
User606491 - Posts: 164
I often put in concurrent buy stop and sell stop orders at different levels as a means to enter a trade. Each entry order includes multiple OCO targets and stops. The expectation is that either the buy stop or sell stop will get hit, and so then I will cancel the inactive order. When using Chart Trade Mode, oftentimes, it can be very difficult to manipulate the targets and stops for the order that gets activated while canceling those for the "inactive" order.
Is there a way to show only buy orders (i.e. show only my buy stop) on one chart and show only sell orders on another chart?
Otherwise, what is a workaround for managing concurrently-placed OCOs?
[2022-05-11 13:59:18]
John - SC Support - Posts: 38598
You can do what you are wanting. You just need to enter the orders on each of the charts separately and make sure the option for Trade >> Only Orders from Chart is Enabled on both charts. Refer to the information here:
Trade Menu: Only Orders From Chart (Trade menu)
[2022-05-11 14:45:34]
Works perfectly.
Thank you.
