Date/Time: Fri, 18 Sep 2026 20:01:54 +0000
Order not filled with no order rejected message
View Count: 1097
[2022-05-10 16:51:33]
User388488 - Posts: 6
I was trading my live account (AMP, CGQ), had put a sell order in place with time enough, price went through the order and it didn't fill, I didn't get any message neither. As this is the second time that happens in the last 5 months, I would like to troubleshoot this issue, understand it and fix it if possible.
The order was a sell stop-limit at 3995.50 at around 9:58 am. Below some facts that may or may not be related:
- I trade the MES from an ES chart.
- The stop-limit order limit offset is set at 0 for both the primary and the attached orders.
- I, initially, always put the order far away from the price I want to enter, then drag and drop it in place once the candle closes. On occasion, if I am a bit slow, the order will be rejected and a message will pop-up (similar to "Trade Order Error - CQG order update. Status: REJECTED. Text: Sell order stop price must be below last trade price ExchangeRejectCode = 2060..."), I understand this. But it was not the case, I believe the order was in place with time enough and there was no message.
- After price crossed the order, I cancelled it fast because I didn't know what would happen if price came back and touched the order again.
I cheked the trade activity log but cannot see anything relevant, so I don't understand the issue. I attached the file.
Could you please support further in order to avoid reocurrence?
Thx in advance.
Private File
[2022-05-11 17:07:18]
The general reason why this would happen:
Is because there is a zero offset for the Limit price:
Date Time Of Last Edit: 2022-05-11 17:07:31
