Date/Time: Wed, 12 Mar 2025 06:26:09 +0000
Coonection Error Message
View Count: 386
[2022-05-10 06:12:06] |
User871209 - Posts: 91 |
Hello, I currently use Denali Data, version 2382. I am getting a message that states "Connection error message from CQG WebAPI. Your session was closed due to a concurrent session" It will disconnect me for a while it continues to attempt to log back in, being that I only have this computer working for SC/CQG could this be a server mistake with CQG or actually someone has my ID and password to log into my account? Would rather think it is not possible someone has stolen my password. Thanks, |
[2022-05-10 10:28:06] |
or actually someone has my ID and password to log into my account? If you are certain you only have 1 installation of Sierra Chart being used with CQG, then this would be the only other possibility .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-10 10:28:13
