Date/Time: Tue, 26 Nov 2024 09:49:27 +0000
Color Bar base on alert condition: add flat color
View Count: 1241
[2014-04-28 20:39:22] |
User99689 - Posts: 27 |
actually color bar are in 2 mode buy or sell color depending only from 1 indicator i use 2 indicators and would like that: indicator 1 and indicator 2 are in up trend (convergence) => buy candle color indicator 1 and indicator 2 are in down trend (convergence) => sell candle color Others configurations (divergence) => flat candle color: stay out: don't take position or flat position I don't know how to take into consideration the second indicator and the third color (flat color). is there an easy way or programming is required for that ? Thanks Date Time Of Last Edit: 2014-04-28 20:41:28
[2014-04-28 20:44:05] |
You need to add a separate Color Bar Based on Alert Condition study to the chart for each color you want to use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
