Date/Time: Wed, 12 Mar 2025 06:32:25 +0000
CQG
View Count: 467
[2022-05-09 20:18:26]
User836964 - Posts: 1
Good morning
I have recently had a sierra chart account, I am at the stage of learning to invest, I have been recommended your platform, I need CQG data, I have also recommended the AMP broker, how to get this data, how to set up an account in AMP to use your platform
Thank you for your help, best regards
Damian
[2022-05-09 21:50:18]
John - SC Support - Posts: 38598
If you have setup your account with AMP, then they would have given you CQG login information. If you have not created your account with AMP, then do that first.
Once you have the account setup, then follow the instructions at the following link for how to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
When you are setup like this, you will be getting the CQG data. Just be aware of the lack of historical data with CQG. Refer to the 2nd bullet point here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351
We highly recommend using the Denali Exchange Data Feed instead of the CQG data. The exchange fees are very similar between the services, therefore you will not be paying anything extra, as you can stop paying for the CQG data feed. Refer to the information at the following link, which includes Setup Instructions:
