Date/Time: Wed, 12 Mar 2025 06:01:54 +0000
Resset platform
View Count: 378
[2022-05-09 20:18:19] |
User491793 - Posts: 1 |
All the setting are bured ad cannot setup my workspace, please resset the softwares for me. |
[2022-05-09 21:44:34] |
John - SC Support - Posts: 38598 |
We are not understanding what you mean by "bured". If you mean "blurred", then that would be something caused by your Operating System or Graphics Card. If you are referring to the new look of the Settings, then refer to the information here: Settings Windows Interface Although we do not recommend resetting your system to the default state, as there usually is no need for it, you can find the instructions for this here: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Resetting Sierra Chart to a Default State For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
