Date/Time: Wed, 12 Mar 2025 06:05:36 +0000
PROBLEM General settings
View Count: 361
[2022-05-09 19:04:06]
lothore - Posts: 6
Bonjour
Il n'est pas possible d'accéder a General settings en cliquant dessus, ca nouvre pas la fenetre
Merci
[2022-05-09 21:23:43]
John - SC Support - Posts: 38598
From Google Translate:
It is not possible to access General settings by clicking on it, it does not open the window
It is opening the window, but most likely it is off the screen somewhere that you can not access it.
Select Window >> Reset Windows to force the windows to reposition to their default location. Then select Global Settings >> General Settings and you should have the window appear properly.
Date Time Of Last Edit: 2022-05-09 21:24:08
