Date/Time: Wed, 12 Mar 2025 06:19:09 +0000
Profit loss not matching real account
View Count: 426
[2022-05-09 15:15:02] |
User276793 - Posts: 55 |
HI. 1 contract tick move on MES futures showing a .25c / tick on sierra in both sim and live. 1 Contract tick move on my IB account showing $1.25 / tick move. Is there a way i can fix this? See screen shorts below thanks |
[2022-05-09 16:34:27] |
John - SC Support - Posts: 38598 |
The P/L in Sierra Chart is being displayed as Points, not currency, hence the reason it has a P after the number. Refer to the following setting if you want to change this: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-09 20:29:43] |
Ahh now i get it. Great thanks!
