Date/Time: Wed, 12 Mar 2025 06:40:25 +0000
"split profile here"
View Count: 678
[2022-05-09 11:38:17]
User914407 - Posts: 49
Bonjour,
Est-il possible de splitter automatiquement les tpo's au fur et à mesure qu'ils se créent ?
Merci
[2022-05-09 15:33:16]
John - SC Support - Posts: 38598
From Google Translate:
Is it possible to automatically split tpo's as they are created?
Thank you
We are not sure exactly what you are looking for, but refer to the following input for having custom intraday sessions:
Time Price Opportunity (TPO) Profile Charts: Number of Custom Intraday Sessions
And also refer to the following for splitting TPOs.
Time Price Opportunity (TPO) Profile Charts: Splitting and Merging TPO Profiles
[2022-05-10 06:36:00]
Bonjour,
Ma question était de savoir si on peux automatiquement splitter les TPO's sans avoir à le faire avec la souris à chaque TPO.
Merci
[2022-05-10 15:47:54]
My question was to know if we can automatically split the TPO's without having to do it with the mouse at each TPO.
The only thing that is close to automatic splitting is the Custom Intraday Sessions. Otherwise, there is no method for automatic splitting of TPOs.
