Date/Time: Wed, 12 Mar 2025 05:59:00 +0000
Disconnections
View Count: 434
[2022-05-09 04:57:30]
User674409 - Posts: 24
I having a lot of disconnections....It got connected like for 5 mins and then Sierra disconnected, there is a message that I need to add credit....but today (08/may/2022)I added credit (36 usd). I have your email confirmation. Please can you check it. Thanks
Ricardo Chavez
imageCaptura de Pantalla 2022-05-08 a la(s) 23.56.08.png / V - Attached On 2022-05-09 04:56:52 UTC - Size: 428.36 KB - 115 views
[2022-05-09 05:06:02]
Your Sierra Chart account is fine.
When you have a disconnection provide the Message Log by following these instructions:
This will provide us the additional information we need.
Date Time Of Last Edit: 2022-05-09 05:06:20
[2022-05-09 13:12:03]
You are the one with the problem....look the messages, still saying I dont have credit, and I already made the pay! Fix it!!!
imageCaptura de Pantalla 2022-05-09 a la(s) 8.09.52.png / V - Attached On 2022-05-09 13:11:44 UTC - Size: 220.38 KB - 117 views
[2022-05-09 13:16:03]
Once again your Sierra Chart account is fine. That message looks like an old message as it is no longer present on your account.
That does not help us. We need to see the Message Log. Are you having a problem currently?
Date Time Of Last Edit: 2022-05-09 13:16:39
[2022-05-09 13:30:25]
there you are...
Software version: 2356 64-bit | 2022-05-09 13:09:34.575
Primary Thread ID: 128 | 2022-05-09 13:09:34.575
Usage end date: 2022-05-07 | 2022-05-09 13:09:34.575
Enabled for: Advanced Features 2. | 2022-05-09 13:09:34.575
Enabled for: Sierra Chart Historical Data Service. | 2022-05-09 13:09:34.575
Enabled for: Delayed Denali Exchange Data Feed. | 2022-05-09 13:09:34.575
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-05-09 13:09:34.576
Current selected Data/Trading service: SC Data - All Services | 2022-05-09 13:09:34.576
Custom symbol settings values: enabled | 2022-05-09 13:09:34.576
Chart Update Interval: 500 | 2022-05-09 13:09:34.576
Intraday Data Storage Time Unit: 0 | 2022-05-09 13:09:34.576
Time Zone: +00:00:00 (UTC+00) | 2022-05-09 13:09:34.576
2022-05-09 13:09:34 Local computer time in UTC | 2022-05-09 13:09:34.576
2022-05-09 13:09:34 Local computer time in SC Time Zone | 2022-05-09 13:09:34.576
2022-05-02 03:08:24 Server time in UTC | 2022-05-09 13:09:34.576
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-05-09 13:09:34.576
Program path: Y:\SierraChart\ | 2022-05-09 13:09:34.576
Data Files path: Y:\SierraChart\Data\ | 2022-05-09 13:09:34.576
OS Version Number: 6.1 | 2022-05-09 13:09:34.578
Locale Setting: C | 2022-05-09 13:09:34.578
DLLs: DOM_Calculation_64-4.dll, UserContributedStudies_64.dll | 2022-05-09 13:09:34.579
Allowed protected custom studies: | 2022-05-09 13:09:34.579
DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-05-09 13:10:31.138
DTC Client socket (1) | Closed. | 2022-05-09 13:10:31.138
DTC Client socket (1) | Deleting network socket now after delay. | 2022-05-09 13:11:31.140
Notice: Sierra Chart usage time has ended. | 2022-05-09 13:28:22.100 *
To activate services and add credit, select 'Help >> Add Usage Credit'. | 2022-05-09 13:28:22.100
[2022-05-09 14:11:24]
Restart Sierra Chart and follow the Forced Login procedure here:
Sierra Chart - Software Login Instructions: Forced Login
Make sure you are logging in with this username/Account Name:
AC123124
