Date/Time: Wed, 12 Mar 2025 05:44:57 +0000
Draw DOM Graph on Chart Behind all Studies
View Count: 825
[2022-05-09 00:02:00] |
RdUbz - Posts: 15 |
Hi, I have the 'Draw DOM Graph on Chart' option enabled under the Market Depth tab in Chart settings. I am wondering if it is possible to have it draw behind all chart studies. Currently, it draws on top of any chart study I add (see attached screenshot). I understand that I can adjust the 'Width in Bars' setting, however, I would like to see if it's possible to just have it draw underneath everything else on the chart. Thanks! |
[2022-05-09 02:13:40] |
No, that is not controllable but you can have blank space on the right side of the chart: Working With Charts: Scrolling The Chart and Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
