Date/Time: Wed, 12 Mar 2025 05:23:40 +0000
Trading Account Required
View Count: 434
[2022-05-08 20:10:16] |
User578003 - Posts: 17 |
I have Denali and Teton Order Routing through EdgeClear and did the required once month login to it and back. But under CME etc in Message Log it has Trading Account Required after doing the required. Am I good to go or is there problem with my account? I had disconnect, pick teton order routing, connect, wait for while, disconnect, pick SC Data - All Services and connect. I assume did this wrong, what is correct steps. Also updated to new version as indicated in support board today
Date Time Of Last Edit: 2022-05-08 20:11:55
[2022-05-09 02:29:26] |
Yes this will continue to always display in the log: it has Trading Account Required
It does not change whether you have verified the trading account once a month.This is what we currently see: Verified trading account ending date: 2022-06-01 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
