Date/Time: Wed, 12 Mar 2025 06:36:54 +0000
Highest volume foot print X bars back
View Count: 585
[2022-05-08 01:00:17]
jmftattoo - Posts: 99
How would I go about identifying the highest volume footprint in a series of “X” foot prints back, then subsequently plot a stacked imbalance style horizontal zone, or extension line from said foot print?
I found this thread that helps identify the logic for highest volume candle x candles back, but it won’t plot extension lines off if it, and I’m not sure how to make that idea work with number bars. Any help would be appreciated. Reference to link that has helped a bit. Special colored volume bars
[2022-05-08 22:39:56]
Anyone? Trying to get this figured out before session tomorrow. If anyone has an idea I’m all ears. Have tried a few different combos and still not able to single out and identify THE highest volume footprint in a series of footprints back.
[2022-05-09 15:23:02]
John - SC Support - Posts: 38598
You really would have to use ACSIL to do what you want. Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL)
