Date/Time: Wed, 12 Mar 2025 05:42:40 +0000
Customize Chart DOM Columns
View Count: 692
[2022-05-07 20:30:17] |
AC109756 - Posts: 18 |
Hello, In "Customize Chart DOM Columns", it would be nice to have an option to align the "Show Volume Bars" of the bid/ask sizes relative to the text alignment. It would be easier visually when using "Combined Bid/Ask Size". Thank you for everything. |
[2022-05-09 02:15:21] |
We will look into this.
