Date/Time: Wed, 12 Mar 2025 05:51:44 +0000
Version required for market data direct from CQG question (below 2391 or below 2383)?
View Count: 526
[2022-05-07 00:54:53] |
User752602 - Posts: 9 |
I'm not able to move to Denali just yet and was wondering about a version discrepancy in your posts. In one post it says to stay on a version prior to 2383 if you are using CQG market data for CME Group or EUREX. Then in another post it says to stay on a version below 2391. Can I get a clarification on this? Thanks 10. For CQG users, support for market data direct from CQG for CME Group and EUREX data is not supported in versions 2391 or higher: |
[2022-05-07 09:24:15] |
You need version 2390 or earlier. But at this time, 2391 does still support CQG market data. No change has been made yet. We still have not yet gotten to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-07 10:27:53
