Date/Time: Wed, 12 Mar 2025 05:55:01 +0000
Futuros de AMP
View Count: 467
[2022-05-06 21:21:08] |
luciana - Posts: 24 |
Hola Quiero recibir los datos desde mi bróker AMP GLOBAL. Me podrían asesorar por favor. Gracias |
[2022-05-06 21:36:32] |
John - SC Support - Posts: 38598 |
From Google Translate: Hello
I want to receive the data from my AMP GLOBAL broker. Could you advise me please. Thank you You need to get connected to your trading service. Since you are with AMP, you are most likely setup to use CQG. If this is correct, then go through the following Setup Instructions to connect to your CQG account for both trading and data: CQG Trading Platform Service: Setup Instructions Just be aware of the lack of historical data when using CQG by reviewing the information at bullet #2 at the following link: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
