Date/Time: Wed, 12 Mar 2025 05:16:59 +0000
Stop to triggered after a certain amount to break even.
View Count: 603
[2022-05-06 19:39:18]
the white rabbit - Posts: 22
Hi
Please tell me how to set up the following...
Hard Stop -20 ticks
Trigger for trail -12 ticks
Close trade at -4 ticks
To explain further, if price exceed 12 ticks set to close the trade at break-even or 4 ticks loss upon pullback. IF not then hard stop will be triggered.
otherwise if the trade is positive not trailing required then.
I have read and tried everything I can think of.
Best regards
[2022-05-06 20:29:20]
John - SC Support - Posts: 38598
The example at the following link gives the setup for what you are wanting:
Attached Orders: Target with Move to Breakeven and Trail Stop Example
[2022-05-06 20:39:06]
Hey John
I want my targets to move to Break-even if the trade is offset ( down ) by a certain ticks.
I dont see the option to move target to B.E. Only Stops.
I want to limit my loss not to cover my profits.
[2022-05-06 20:58:28]
I want to set up my trade window so my target move to B.E if the trade goes against a certain number of ticks ??
To explain further,
If i buy at 10 and the price goes to 7 then all targets move to breakeven, otherwise a hard stop at 5 will be hit.
Thank you
[2022-05-06 21:20:45]
Sorry, we did not recognize that you had specified Targets.
We do not have a way to move Targets to breakeven like there is for Stops.
You might be able to put something together using the Spreadsheet System for Trading. Refer to the information here:
Spreadsheet Systems, Alerts and Automated Trading
Otherwise, you would have to create a custom study to do what you want. For this, refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL)
