Date/Time: Thu, 28 Nov 2024 00:23:47 +0000
Source code editor don't open
View Count: 945
[2022-05-06 18:28:36] |
PCleveland - Posts: 4 |
Hi there, I find it disturbing when I click the NEW/OPEN CUSTOM STUDY FILES, and there's no nothing showing up. It used to open, but this only happen since today. I can still open notepad++ from explorer but it's annoying. I just can't open files from the analysis tab. Do you have any suggestion? |
[2022-05-06 18:40:34] |
I also find it confusing that, given my program was installed on D drive, but on the message log it says on C drivee. Created process C:\SierraChart\NPP\notepad++.exe. Current folder: C:\SierraChart\NPP | 2022-05-06 14:24:54.983 Created process C:\SierraChart\NPP\notepad++.exe. Current folder: C:\SierraChart\NPP | 2022-05-06 14:36:10.721 No idea why it becomes this and how to fix it |
[2022-05-06 20:20:48] |
The editor that is used when you select New/Open Custom Study Files is defined under Global Settings >> General Settings >> Paths >> Text Editor Path and Filename. Make sure this is set to the editor you want to use. There is a Notepad++ that is sent with Sierra Chart and is located under the main Sierra Chart installation folder in a folder named NPP, so the path and file name would be [Sierra Chart Installation Folder]\NPP\notepad++.exe. Refer to the following for more information: General Settings Window: Text Editor Path and Filename (Global Settings >> General Settings >> Paths >> Files and Folder Paths) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-07 02:56:56] |
Hi, I noticed this option, and it's the default path which in my case is D drive. I did have a SIERRA CHART folder in C drive, but it's not the program path that I am using. So, I moved the C drive folder. Then I got this msg. Error creating process C:\SierraChart\NPP\notepad++.exe. Windows error code 2: The system cannot find the file specified. | 2022-05-07 00:11:11.079 * Error creating the Advanced Custom Studies editor process. | 2022-05-07 00:11:11.079 * So it's confusing that even the program path set to be on D drive but the msg log still shows a C drive. And in the general setting/path/editor, I am using the default notepad++ which is in D drive. Thanks Date Time Of Last Edit: 2022-05-07 04:18:27
[2022-05-07 17:15:26] |
Change the editor through Analysis >> Build Custom Studies DLL >> File >> Select Editor.
[2022-05-07 17:38:53] |
Documentation: Advanced Custom Study Interface and Language (ACSIL): Setting the Default Code Editor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-07 17:38:57
[2022-05-07 18:09:44] |
Got it! Thanks
