Date/Time: Wed, 12 Mar 2025 05:46:05 +0000
heiken ashi candle stop loss
View Count: 601
[2022-05-06 16:29:23] |
Matador Trader - Posts: 24 |
Good Day! I would like to place a trailing stop that goes right on top of the previous HA candle so that if the candle does not have a flat top/bottom - I am out of the trade. Is this possible? Thanks in advance. |
[2022-05-06 16:39:24] |
John - SC Support - Posts: 38598 |
If we are understanding what you want, you would use a combination of the Spreadsheet Formula and the Trade Management by Study studies. On the Spreadsheet Formula you would enter the following formula: =H[-1] This establishes a level for the current bar that is the previous bar's high. Then you would use the Subgraph from the Spreadsheet Formula for the Trade Management by Study. Refer to the following for the Spreadsheet Formula: Spreadsheet Formula Refer to the following for the Trade Management by Study: Attached Orders: Study Controlled Targets and Stops For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-06 21:51:23] |
ok - i know what i'll be doing this weekend! Thanks!
