Date/Time: Wed, 12 Mar 2025 05:46:46 +0000
I cannot connect CQG data to SC
View Count: 599
[2022-05-06 10:16:35]
User266447 - Posts: 270
I cannot connect CQG data to Sierra. It shows invalid password or username. My login details are correct. What else can I do? Can I ask for a remote support? I have temaviewer.
Thank you in advance,
Arek
[2022-05-06 10:45:28]
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-05-06 10:59:25]
I have copy the message log and sent for analysis.
Could you review it, please?
[2022-05-06 11:11:09]
This is what we see:
CQG WebAPI | Logon unsuccessful. Server message: Username or password is incorrect. | 2022-05-06 10:53:50.949
Refer to item 5 here:
CQG Trading Platform Service: Common Error Messages
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
[2022-05-06 12:12:31]
Do I have a delay in the data feed? I bought it data from CQG/COMEX. On MT for gold is going up and on Sierra is going down.
What is the reason?
[2022-05-06 12:14:10]
Sorry, regarding my prevous post, I bought data from AMP. I bought CQG/Comex. Gold price goes up on my MT4 platform wherease in SC goes down? Do I have a delay on data feed?
[2022-05-06 12:31:21]
If you cannot connect to CQG, and have follow the instructions in post #4 to connect to SC Data-All Services until you can solve the CQG connection problem, then in your case to data will be delayed by 10 minutes.
Date Time Of Last Edit: 2022-05-06 12:31:32
[2022-05-06 12:36:15]
Thank you for your reply.
How can I solve the CQG-data connection? With whom? AMP checked and said that everything is fine on their side. Now you who can support me on this issue. Please - can we schedule a remote support? It will take probably a few minutes and this will be solved.
Please...
[2022-05-06 12:46:56]
You definitely do not need our help, to enter the username or password. You can do this. The instructions are here:
CQG Trading Platform Service: Setup Instructions (follow steps for 6 through 10)
We have no idea what your CQG username and password are.
Date Time Of Last Edit: 2022-05-06 12:47:14
[2022-05-06 12:53:02]
I have provided the correct CQG login and password - the details I have received from AMP. And I have an error. Cannot log in.
Could you support me on this please? To resolve it. The best way is to use the remote support.
[2022-05-06 13:53:44]
AMP helped me out! It is solved now.
Thank you SC.
