Date/Time: Wed, 12 Mar 2025 05:45:58 +0000
No date in SC
View Count: 395
[2022-05-06 06:08:06]
User447599 - Posts: 11
Hi all,
since yesterday evening I do not receive any chart data via Denali feed. I already downloaded the current version, installed it but did not change anything. Sying "Historical download skipped". I already clicked >>Delete All Data and Download", the measssag log is attached.
Thanks and best regards
Sarah
Date Time Of Last Edit: 2022-05-06 06:42:50
imageScreenshot_1.png / V - Attached On 2022-05-06 06:17:01 UTC - Size: 35.38 KB - 110 views
[2022-05-06 07:18:42]
The reason you are not getting real-time or historical data from the Denali Exchange Data Feed for the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
