Date/Time: Wed, 19 Mar 2025 04:31:02 +0000
Requesting Account balances for web-based Teton Trade Account Data and Order Entry
View Count: 955
[2022-05-05 22:40:23]
User35525 - Posts: 182
I'm using Teton with Stage5/Dorman and placed trades today, but cannot request a log of account balance history at
>> Account Control Panel >> Trade Account Data and Order Entry.
The "Account Balance" section correctly shows the correct account balance, but the "Account Balance History" section has error "No Account Balances".
I should be on Teton, but authorized trading accounts shows service "tt_order_routing.dtc.trading".
Date Time Of Last Edit: 2022-05-05 22:45:17
[2022-05-06 11:47:49]
Make sure you are using this web-based trading panel:
https://www.sierrachart.com/UserControlPanel.php?page=TradeAccountDataAndOrderEntry_v2
[2022-05-06 18:29:55]
Sorry that didn't help
Account Control Panel >> "Web Trade Account Data and Order Entry" shows CME direct order routing (is that TT?) I should be on Teton. I was setup on Teton in January and my SC logs show I'm connecting to Teton.
Account Control Panel >> "Trade Account Data and Order Entry - Live SC Order Routing" is also available (is that Teton?).
Is the Teton Account Balance history section broken at the moment? It was very helpful before but isn't functioning now. I also tried a different browser and clearing browser cookies to fix it.
Date Time Of Last Edit: 2022-05-07 00:28:28
[2022-05-08 11:23:48]
Sierra_Chart Engineering - Posts: 18837
We will check on this. This refers to Teton:
[2022-10-11 14:17:56]
eminimom - Posts: 24
I used the link cited in this thread for the Web Connect Browser display of trades, etc. It is disconnecting every 60seconds. What other settings do I need to check for Teton/Stage5. Thanks
[2022-10-11 15:44:31]
John - SC Support - Posts: 38782
When you get to the Service Selector after entering your password, make sure you are selecting the option named Trade Account Data and Order Entry - Sierra Chart CME Direct Order Routing.
If you are doing this and still getting disconnected, then please let us know.
[2022-10-11 17:14:56]
Still not functioning.
Once I have this: Trade Account Data and Order Entry-Sierra Chart CME Direct Order Routing, the next page that pops up is Server Selector/Sierra Chart CME Direct Order Routing-Advantage-Stage 5.
Then Connection Status, I selected Connect and it only stays on for less than 60seconds for Connected (Trading) and Connected(Data).
They both go to False time after time. My SC DTC Server. Build=43568 Data: SC Realtime Server.
[2022-10-13 13:58:13]
