Date/Time: Wed, 12 Mar 2025 05:23:57 +0000
Cumulative delta bars showing emptiness
View Count: 564
[2022-05-05 19:53:11] |
User474875 - Posts: 7 |
dear support, Please see attached image that the Cumulative delta bars showing no graph data in historical charts. Please help. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=64073 |
[2022-05-05 20:32:35] |
John - SC Support - Posts: 38598 |
The Cumulative Delta Bars - Volume depend on the Bid and Ask information for the trades, but this information does not exist in historical daily data. Therefore, this study does not work on historical daily data. You have to use Intraday data. If you want a daily, or higher timeframe, then you will want to set the Chart Data Type to Intraday Chart Only. Refer to the information here: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
