Date/Time: Fri, 18 Sep 2026 23:18:18 +0000
Would Like to trade on Sierra with the AMP brokerage..Please
View Count: 599
| [2022-05-05 19:52:45] |
| RickyBoy - Posts: 1 |
I want to receive real-time futures data and I have a funded futures trading account with AMP futures. I want to access real-time futures data and ability to trade with AMP on Sierra Charts. I have already purchased the Denali package through Sierra. Thank you.
| [2022-05-05 20:29:36] |
| John - SC Support - Posts: 47939 |
You need to connect your Sierra to your CQG account (AMP should have set you up to CQG for order routing and given you login credentials for CQG). To do this, follow these instructions: CQG Trading Platform Service: Setup Instructions When you finish that, then open your chartbooks and select Edit >> Translate Symbols to Current Service. This will change the symbols in your charts to match what CQG uses. After that, you should be fine and you should be getting the real-time data from our Denali feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
