Date/Time: Tue, 26 Nov 2024 11:22:49 +0000
Daily Change and Daily Change % not working
View Count: 1260
[2014-04-28 15:13:40] |
User19625 - Posts: 12 |
Daily Change and Daily Change % indicators in Chart header not working http://www.sierrachart.com/image.php?l=1398697983263.png |
[2014-04-28 15:39:26] |
This is with CQG. We looked into this and we are using the correct fields from CQG to set these. Apparently there is some problem with the data from CQG. We will be looking into that later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-01 19:09:39] |
still the problem is on
[2014-05-01 19:42:36] |
@sstfrederik - Posts: 404 |
i have the same issue. daily change in top of chart screen displays zero.however the bar change does work.
[2014-05-01 20:14:48] |
the bar works, the daily has the prom
[2014-05-06 13:26:24] |
please, are you gonna fix this issue? the Daily indicators are very critical and I need them I subscribed today for Sierra, by the way, for one year package 5 thanks a lot |
[2014-05-06 19:02:38] |
We now see why the Daily Price Change remains at zero when using the CQG Trading service. This will be resolved in the next release coming out today or tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-06 19:03:11
[2014-05-06 19:26:01] |
thank you for your prompt action
[2014-05-08 03:48:27] |
nothing yet
[2014-05-08 06:44:25] |
We should have a new release out in about two hours.
