Date/Time: Wed, 12 Mar 2025 05:48:44 +0000
[Programming Help] - What am I doing wrong? Combining scsf_BarTimeDuration and scsf_BackgroundDrawStyleExample
View Count: 529
[2022-05-05 03:00:32] |
silvereagle - Posts: 23 |
Hi friends. I was attempting to write a study that changed the color of the background of a bar-column based off a duration of seconds ---I use a lot of different colors for different things so my needs go beyond primary/secondary/etc. I know this is possible using Color Background Based on Alert Condition with appropriate formulas, and I've done this in the past but I was looking for more advanced control from an ASCIL study. I was attempting to "blend" two sierra studies into my own unique one, but I just cant get this to work. I gotta be missing something. Code Below. Many thanks to anyone who can nudge me in the right direction. - scsf_BarTimeDuration - scsf_BackgroundDrawStyleExample My thought was to: 1. Get the time difference 2. Get the seconds from that TimeDiffDateTime 3. Set Subgraph_BackgroundDC.DataColor to RGB color This is my code, mostly taken from the sierra studies themselves. SCSFExport scsf_BackgroundDrawStyleExample(SCStudyInterfaceRef sc) { SCSubgraphRef Subgraph_BackgroundDC = sc.Subgraph[0]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Background DrawStyle Example"; sc.StudyDescription = "Background DrawStyle Example"; sc.AutoLoop = true; sc.GraphRegion = 0; sc.DrawStudyUnderneathMainPriceGraph = 1; // not required in studies, but want color behind price for this study Subgraph_BackgroundDC.Name = "Background DataColor"; Subgraph_BackgroundDC.DrawStyle = DRAWSTYLE_BACKGROUND; Subgraph_BackgroundDC.PrimaryColor = RGB(255, 255, 255); return; } // Step 1: Get duration // code from: scsf_BarTimeDuration SCDateTime BarEndDateTime = sc.GetEndingDateTimeForBarIndex(sc.Index); double TimeDiff = static_cast<float>((BarEndDateTime - sc.BaseDateTimeIn[sc.Index] + SCDateTime::MICROSECONDS(1)).GetAsDouble()); // Step 2: Get seconds from duration SCDateTime TimeDiffDateTime = SCDateTime(TimeDiff); int BarDurationAsSeconds = TimeDiffDateTime.GetTimeInSeconds(); if (BarDurationAsSeconds >= 0 && BarDurationAsSeconds < 15) { Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(204, 153, 255); }; if (BarDurationAsSeconds >= 15 && BarDurationAsSeconds < 30) { Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(51, 204, 51); }; if (BarDurationAsSeconds >= 30 && BarDurationAsSeconds < 45) { Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(158, 70, 255); }; /* ---------------------------------------- * code from scsf_BackgroundDrawStyleExample * ----------------------------------------- int min = sc.BaseDateTimeIn[sc.Index].GetMinute(); if (min > 0 && min < 15) Subgraph_Background[sc.Index] = 0; // do not color background else if (min >= 15 && min < 30) Subgraph_Background[sc.Index] = 1; // use primary color else if (min >= 30 && min < 45) Subgraph_Background[sc.Index] = -1; // use secondary color else if (min >= 45 && min < 60) { Subgraph_BackgroundDC[sc.Index] = 1; Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(0, 0, 17 * (60 - min)); } */ } |
[2022-05-05 15:58:42] |
JohnR - User831573 - Posts: 319 |
Maybe you did not share your entire code, but if this is all you have, then you need a few lines at the top of every file before it will compile. // The top of every source code file must include this line #include "sierrachart.h" SCDLLName("My test DLL ") /*============================================================================*/ If that is not the problem, what is the problem? Does it compile and run, but do nothing? Do something, but not what you wanted? JohnR |
[2022-05-05 16:17:03] |
User431178 - Posts: 613 |
Try actually assigning a value to the subgraph, similarly to how scsf_BackgroundDrawStyleExample does. if (BarDurationAsSeconds >= 0 && BarDurationAsSeconds < 15) { Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(204, 153, 255); Subgraph_BackgroundDC[sc.Index] = 1.0f; }; if (BarDurationAsSeconds >= 15 && BarDurationAsSeconds < 30) { Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(51, 204, 51); Subgraph_BackgroundDC[sc.Index] = 1.0f; }; if (BarDurationAsSeconds >= 30 && BarDurationAsSeconds < 45) { Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(158, 70, 255); Subgraph_BackgroundDC[sc.Index] = 1.0f; }; |
[2022-05-05 17:40:52] |
JohnR -- Thanks for the message, but yes I just shared the body of code ---I do have everything there and can compile just fine, but thank you for taking the time to reply :) User432278 -- Thank you sir. That appeared to be it. Knock on wood anyway. Once I added that additional line to each if block, Subgraph_BackgroundDC[sc.Index] = 1.0f;
Then the bar columns appeared with colored backgrounds. Wow. I wont tell you how much time I blew on that. :) Thanks everyone. |
