Date/Time: Wed, 12 Mar 2025 05:31:04 +0000
current price line and current bid ask lines
View Count: 492
[2022-05-04 20:30:21]
User 144164 - Posts: 17
220504-1529
TITLE
GOAL:
have both of the above to extend from left side to price scale to right side to price scale regardless of amount of fill space.
PROBLEM:
I have tried a variety of settings and it extends exactly as the stated goal is only on some charts. Even if the settings are exactly the same on another chart with similar fill space and days loaded etc the result is not consistent.
I am running both studies on the same chart simultaneously in some cases but that does not seem to affect the result.
The instructions on SC site have been read and followed but to no avail.
Thank you for your assistance.
[2022-05-04 20:52:24]
220504-1549
MESSAGE #2 RE
CURRENT PRICE LINE + BID ASK LINES
In case you need this info:
I am running version 2348 64bit
I was told by Transact this is the latest version that works for a
transact user.
As you know, I am using Denali.
I am a bit puzzled as Ray told me Denali was much better than Teton,
which I was using with Transact. As soon as he told me that I opted
for Denali when I switched from paying Transact for your services to
paying you directly. Hoewever notes on your site indicates Teton is
recommended. I do not know if any of the above has anything to do
with the problem of not getting the current price and bid ask lines
to extend from left chart margin to right chart margin.
Thanks in advance for your assistance
[2022-05-04 22:18:16]
John - SC Support - Posts: 38598
We do not know what exactly is the issue you are having, but if you do the following you should not have any issues:
- Set the Input for Number of Bars to Display On to a large value, like 10000.
- Set the Subgraph Draw Style for each of the lines to Line from End of Chart Left to Right.
You will find the information for the Draw Style here:
Chart Studies: Line at Last Bar Left to Right (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_LEFT_TO_RIGHT)
Teton is an Order Routing Service, whereas Denali is a data feed. These are two completely separate things.
If you are staying with TransAct, then you do not have access to the Teton Order Routing Service. If you are interested in using this, then you would have to change brokers. Refer to the information for this service here:
The information for the Denali Exchange Data Feed can be found here:
