Date/Time: Wed, 12 Mar 2025 05:33:19 +0000
Sierra data feed and order routing CQG
View Count: 449
[2022-05-04 16:39:52] |
roger Down - Posts: 2 |
I have a live account with AMP futures and they have supplied, CQG order routing only for me to trade live. I have Service package 11 with you and the Denali feed. How do I access the live account to trade ES at CME, please? |
[2022-05-04 21:31:26] |
John - SC Support - Posts: 38598 |
The first thing you need to do, if you have not already done so, is to connect your Sierra Chart to your CQG account. Follow the instructions at the following link for this: CQG Trading Platform Service: Setup Instructions The second thing is then to finish the setup for the Denali Exchange Data Feed. Since you are wanting data for the CME Group, go through all of the instructions starting here: Denali Exchange Data Feed: Sign the Agreements: The CME Group (Denali Exchange Data Feed Setup Instructions) Once you have the Denali Exchange Data Feed all setup and the exchange(s) activated, then open your chartbooks and select Edit >> Translate Symbols to Current Service. This will make sure that your charts are using the symbols necessary for CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
