Date/Time: Wed, 12 Mar 2025 05:17:55 +0000
Activate Forex Data feed
View Count: 408
[2022-05-04 16:35:52] |
User494044 - Posts: 2 |
Hello. I am confused on how to achieve the following scenario. I have just completed my trial access to SC. I want to use the Historic Data or Simulated Data feeds to use Chart Replay or Trade simulation. I am trying to buy the $25 historic data package but it's not allowing me to checkout. What exactly do i need to sign up for or do to make this happen?? I have these broker accounts: AMP, Phillips, Forex, Oanda. Thank you, Andrea |
[2022-05-04 21:05:15] |
John - SC Support - Posts: 38598 |
There is no charge for the historic data. As long as you are not wanting real-time data, then as long as you have an active Sierra Chart account, then you have access to all the historic data; delayed streaming data for the CME Group, EUREX, CFE, and NASDAQ TotalView; and real-time data for CFD and FOREX. The only thing you need to do is to activate a package. Your account is currently expired. Follow these instructions to add funds and select a package: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
