Date/Time: Wed, 12 Mar 2025 05:44:48 +0000
Need help to link with Teton
View Count: 581
[2022-05-04 13:31:16] |
John910 - Posts: 12 |
Hello, Contacted IB this morning and they say I should get email from SC. Can you guys complete the setting up? I can't subscribe to CME agreement because I need to log in to Active Account first right? When selecting Teton as trade service connection gives "No trade accounts assigned" They are telling it was set up since yesterday morning. Please advise. Thanks |
[2022-05-04 13:34:53] |
Who is the broker you are using for Teton?
[2022-05-04 13:43:06] |
Ironbeam
[2022-05-04 14:56:22] |
John - SC Support - Posts: 38598 |
Make sure you have gone through all of the Setup Instructions starting at Step #6 here: Sierra Chart Teton Futures Order Routing: Setup Instructions If you have everything setup correctly and are still getting the notice about the account not being assigned, then you will need to let IronBeam know about this, as they have not completed something on their end. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-06 12:09:27] |
Make sure they have your Sierra Chart Account Name/Username from Help >> About from within Sierra Chart.
