Date/Time: Tue, 26 Nov 2024 09:24:10 +0000
ES data for demo
View Count: 951
[2014-04-28 01:28:31] |
Larry - Posts: 1 |
Hi, I'm evaluating Sierra Chart as a second source for out trading platform. I'm a long term user of Nina. Unfortunately we use Kinetick so I can use that data feed right now. I've got the SPX up and running just fine on the demo. I'm connected to SC Forex Data (FXCM). I can't for the life of me find how to connect to ES CME. Is there a way to get at the ES CME from where I am right now or should just subscribe to exchange data? I apologize for the basic question if I haven't done enough home work. Thank you, Larry |
[2014-04-28 01:58:27] |
Refer to this section here about this: https://www.sierrachart.com/index.php?l=doc/data.php#FuturesData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
