Date/Time: Wed, 12 Mar 2025 05:43:07 +0000
I trade Es and want to being it on my charts
View Count: 415
[2022-05-04 02:21:16] |
TradingInDemand - Posts: 24 |
hello, just got my account set up and denali + cme activated but it seems my charts only load MESM22_FUT_CME and when I try to load ESM22_FUT_CME it stays on "waiting to download Historical Data"
[2022-05-04 13:50:10] |
John - SC Support - Posts: 38598 |
It should not be stopped there, but there is a separate issue - which is that you have not fully activated the Denali Exchange Data Feed. In particular you do not have any exchange active for your account. You can activate the exchange(s) here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Once you get the exchange setup, then let us know if you are still having an issue with ES. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-04 18:07:34] |
This means that there is another download in progress and the one that shows waiting to download is pending. The download will eventually start and finish.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-04 18:07:46
