Date/Time: Wed, 12 Mar 2025 05:38:32 +0000
[User Discussion] - TWS API delay
View Count: 1086
[2022-05-03 19:04:40]
User8135477 - Posts: 133
I have been using the API with IB TWS software for quite some time now, but this problem is fairly recent. The order fills go through with no problem, but there seems to be +10-30 sec. delay in showing up on the Sierra Chart platform, especially if putting through multiple orders within a short time frame. This seems to be happening since my last update. Please advise.
[2022-05-04 02:47:15]
Belebala - Posts: 15
I had the similar problem before and after I switch my TWS latest version back to TWS 981.3f or the latest TWS981.3 version that you can download from IB, the problem disappear. Hope this help.
Date Time Of Last Edit: 2022-05-05 04:13:32
[2022-05-04 13:10:11]
Thank you. How did you switch the TWS back to an older version?
[2022-05-04 14:06:58]
I just tried to look into all options to change my TWS back to an older version. Unfortunately, it is not available.
To Sierra Chart support - can you please look into this problem and provide a proper update? It would be much appreciated.
[2022-05-05 01:26:42]
Tonkadad - Posts: 235
https://www.interactivebrokers.com/en/index.php?f=14099#tws-software
Looks like the oldest version you can get is 981.3
[2022-05-05 02:17:23]
yes, for 981.3n, but not f or x.
[2022-05-05 04:14:56]
Sorry there is no x, I mean the latest 981.3 version that you can download from IB
[2022-05-05 21:04:34]
https://groups.io/g/twsapi
The above group is pretty active and someone probably has a link to an earlier version of TWS.
[2022-05-06 02:39:11]
Sierra_Chart Engineering - Posts: 18750
This could not be an issue on the Sierra Chart side:
Date Time Of Last Edit: 2022-05-06 02:39:42
[2022-05-06 02:46:21]
The order fills are processed immediately on TWS, but there is a delay in the fill actually showing up on Sierra Chart. How then can you be so sure that this is not an issue on the Sierra Chart side?
