Date/Time: Wed, 16 Sep 2026 01:20:00 +0000
[Programming Help] - SPREADSHEET TRADING
View Count: 1226
[2022-05-03 17:56:55]
User397996 - Posts: 18
Quick question: i've built several trading systems and would like to put them all in one sheet to play on same symbol but it seems only columns K-N are valid for orders, correct?
I can't put two sets of conditions through K-N and O-R columns.
I must put the conditions on columns O-Z and then direct them to K-N to place the orders, is that it?
[2022-05-03 21:22:49]
Sawtooth - Posts: 4353
Yes.
Suggestion:
Use columns O-R for one system's signals, and columns S-V for the other system, then use the OR function in columns K-N referencing each system.
[2022-05-04 10:37:21]
Another question: i have two similar spreadsheets with a flatten order at 15:30:00 CT but only works on one of them.
I've compared them and can't see the difference. I even tried a formula on cell J29 but still it doesn't work.
Can you help? Thanks
Private File
[2022-05-04 14:09:22]
Is autotrading disabled at 15:30 by another cell (J28) or formula?
[2022-05-04 17:07:57]
NO, NO FORMULA HAS ANY TIME CONSTRAINTS.
I'VE SENT YOU THE .SCSS FILE ATTACHED.
I HAVE THOUGH AN ALLOWED TIME RANGE BETWEEN 9AM - 3PM (J86/J87) AND ON J89 TO FLAT AT 3.15PM
[2022-05-04 22:35:38]
I personally don't use J85-J89.
I think if J89 is >= J87, J89 doesn't happen, and there is no way to override J87 for exits.
To avoid this I use formulas like these:
J28:
=AND(J8=0,OR(FRACTIME(J41)<TIMEVALUE("09:00:00"),FRACTIME(J41)>TIMEVALUE("15:00:00")))
J29:
=FRACTIME(J41)>TIMEVALUE("15:15:00")
J8=0 disallows entries after the end time but allows J28 to remain FALSE (autotrading enabled) after 15:00 so that J29 can execute.
J29 needs to be later than the end time.
[2022-05-07 23:26:12]
Thanks for your help.
I have another question: i'm trying to extract the RTH Open value out of a 1m chart (24h) and used this formula without success: =VLOOKUP(TIMEVALUE("08:30:00"),$A$3:$B$600,2,1)
Can't see what i'm doing wrong, can you help?
[2022-05-08 02:18:23]
In a Formula Column, use the FRACTIME function to return only the Time of Day from the Serial DateTime of column A, e.g. cell O3:
=FRACTIME(A3)
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#FRACTIME_Function
Then use the GETCORRESPONDINGMATCH function to return the Open price in column B at 08:30 in column O:
=GETCORRESPONDINGMATCH(O3:O600,TIMEVALUE("08:30:00"),1,0,0,B3:B600,0)
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#GetCorrespondingMatch_Function
