Date/Time: Tue, 15 Sep 2026 11:43:15 +0000
Trade and Current Quote Symbol
View Count: 1106
[2022-05-03 13:15:14]
User361939 - Posts: 169
I was testing Trading e.g MCL with chart of CL.
I see that Trade is properly executed on MCL but it seems that attached orders doesn't work for this option.
Could you tell me how can fix this issue?
Best Regards
[2022-05-03 17:05:46]
Really should not be any problem. We see you are using Transact. Check the Trade Activity Log to see why there may be a problem with the Attached Orders:
Trade Activity Log: Viewing Historical Trade Activity
[2022-05-09 14:21:38]
now its working fine. Maybe it was some one time issue.
[2022-06-15 15:28:41]
One question more:
If I trade e.g BUY ORDER CLN2/MCNL2
and on chart i put on level 100
will it mean that Position will open on MCNL2 only when price touched level 100 on CLN? AM i correct?
Best Regards
[2022-06-15 15:49:24]
Are you referring to an order with a price of 100? That would be triggered, based upon micro crude oil.
[2022-06-15 20:09:39]
Is it posible to setup chart so it will be triggered by price on CL by exucuted on MCL?
[2022-06-15 20:34:30]
John - SC Support - Posts: 47889
You would have to use a Client-Side order to do this and put it on the CL Chart with MCL as the Trade Symbol. Refer to the information for Client-Side order types here:
Order Types: Fully Client Side Managed Orders
[2022-06-16 06:30:21]
Is this possible to setup it from sierrachart or it is only available via broker?
[2022-06-16 15:43:51]
You would have to do it within Sierra Chart using a Client order type. You can NOT do it through the broker, that is the point. These orders would only exist on your local system until the criteria is met to then send them to the market.
