Date/Time: Wed, 27 Nov 2024 14:31:11 +0000
Order Allocation and Adjusting Orders on Multiple Accounts
View Count: 921
[2022-05-03 12:31:22] |
User636370 - Posts: 20 |
Hello, I recently updated SC to v2386 and it now seems that dragging (or, cancelling) an open order when Chart Trading also moves (or, cancels) the order on order-allocated accounts as well. Looking through the documentation I could find (Order Allocation to Trade Accounts: Introduction) I didn't see specifics to indicate that orders can now be modified across all accounts. I understand you've recently made adjustments to this functionality, so I want to be sure as I've been holding off on adding more accounts to my data feed due to the difficulty in previously managing/editing open orders on the chart. Does dragging/adjusting orders when Chart Trading also adjust open orders that are sitting on order-allocated accounts as well? If true, this is a game-changer. Thank you for incorporating this functionality! Regards, |
[2022-05-03 13:19:36] |
Yes and it is explained here: Order Allocation to Trade Accounts: Functionality However, we recommend testing all of this functionality with Trade Simulation Mode: Trade Simulation And making sure it all works as intended. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-03 14:14:34] |
Great news! I'll do that. Thanks again. |
[2023-07-12 16:12:35] |
User191165 - Posts: 28 |
Hello, I've been using "Order Allocation to trade Accounts" for sometime now and with few issues. It's a great function, thanks Sierra team. I have read your instructions and followed them as advised and the function has worked well. As per usual on a new trading day I go through my checklist and make sure all is setup as I like it, including "Order Allocation". Of recent, sometime in the trading day the function randomly disables. When I save & close charts and then reopen the function is no longer enabled? Please advise. Regards Date Time Of Last Edit: 2023-07-12 16:18:42
[2023-07-12 16:53:37] |
user_xyz - Posts: 416 |
I've noticed this too in the last week and just tested Trade Window -> Settings -> Enable Order Allocation To Trade Accounts - Does not Save setting and defaults to unchecked on restart of Sierra Chart.
Date Time Of Last Edit: 2023-07-12 17:07:21
[2023-07-13 15:54:29] |
Also noted that when you reset child windows, this disables it too
[2023-07-31 18:16:09] |
User394029 - Posts: 5 |
This also happens when starting SC up. For some reason I need to "Enable Order Allocation To Trade Acccounts" every time I open SC - is there a way to set it to "Enabled" as default?
[2023-07-31 20:41:52] |
John - SC Support - Posts: 36312 |
Refer to the following: Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
