Date/Time: Tue, 26 Nov 2024 09:40:45 +0000
How to link two or more charts
View Count: 1296
[2014-04-27 22:48:28] |
crow - Posts: 3 |
Is there a way to link two or more charts of different time frames so that they change simultaneously with a single symbol entry on one of the charts? Thanks.
[2014-04-27 23:07:28] |
Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
