Date/Time: Tue, 11 Mar 2025 18:06:55 +0000
Exceeding the minimum bar space allowed by default
View Count: 429
[2022-05-03 04:21:14] |
User50927 - Posts: 91 |
Hello support, I really need your help figuring out how to collapse the bar spacing in the range-bar chart below beyond the maximum allowed by your program in order to view as many days of data as possible without having to manually scroll back the chart. I'm only interested in how the data shown at the bottom of Region #1 (the numbers) and/or Region #2 (the subgraph) looks - i.e. not the price bars themselves - and as you can see, I still have plenty of space left in between data points when I decrease the bar spacing as far as possible. Another option would be for you to come up with an alternative way to display what I actually care about which is the total number of range bars per day. I tried for hours to find a study or combination of studies that would count the total number of range bars per day and then overlay the tally onto a daily chart as bars in Region #2. https://www.sierrachart.com/image.php?Image=1651550781238.png |
[2022-05-03 14:03:21] |
John - SC Support - Posts: 38581 |
If you are only interested in the data that is of a higher timeframe, then you should change the chart to be the same timeframe as that data. That will decrease the number of bars and allow you to compress the screen down. Otherwise, there is no other solution. The smallest you will be able to compress a chart is always going to be limited to a certain number of bars, so to be able to see more time, you would need to use higher timeframe bars. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
