Date/Time: Thu, 24 Sep 2026 21:12:51 +0000
TETON order reject 107 invalid securitydesc
View Count: 810
| [2022-05-03 03:23:08] |
| User220914 - Posts: 239 |
hello getting an error in teton order routing 107 invalid secutirydesc tag 107 this is in the micro nq oe mnq march 22 however the same nomenclature for mesm22_fut_cme is allowing me to make trades in the micro sp500 please tell me what I am doing incorrectly thank you |
| [2022-05-03 04:28:39] |
The problem is, you are using lowercase characters in the symbol. The CME requires uppercase. Do not hand type the symbols but choose them from File >> Find Symbol. You need to change the symbol through Chart >>Chart Settings>> Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-03 04:28:55
| [2022-05-03 06:04:11] |
awesome thank you
