Date/Time: Tue, 11 Mar 2025 17:56:59 +0000
Stop Order Confusion
View Count: 478
[2022-05-03 00:23:03]
Ankn - Posts: 11
Which stop order accomplishes the following: I enter long, I want a stop order to be placed Y ticks above entry price after the position is UP X ticks. EX: Once position is up 20 ticks put a stop 9 ticks above breakeven.
I would think this is simply a stop: triggered stop but its working in the opposite manner.
[2022-05-03 13:54:08]
John - SC Support - Posts: 38581
A Triggered Stop will not work, as that is expecting the movement to be against you.
You would just need to setup a standard stop and use the Move to Breakeven option, which will allow you to set a particular trigger offset and a breakeven offset. Refer to the information here:
Attached Orders: Move to Breakeven for Stop
[2022-05-03 14:08:53]
Yes you would want to use the Move Stop to Breakeven functionality.
