Date/Time: Sat, 19 Sep 2026 01:06:40 +0000
value of additional-symbol on high of primary symbol
View Count: 711
| [2022-05-02 22:45:22] |
| Bedhog - Posts: 187 |
In this image I have the MNQ in Region 1 and TICK-NASDAQ in Region 2. How can I get the value of TICK-NASDAQ to appear above each bar of the MNQ ? |
| Attachment Deleted. |
| [2022-05-03 13:40:16] |
| John - SC Support - Posts: 47939 |
Use the Study Subgraph Above/Below Bar As Text study and make sure the Region is set to Region 1. Refer to the following for the study: Study Subgraph Above/Below Bar as Text Refer to the following regarding setting the region: Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
