Date/Time: Sun, 27 Sep 2026 10:09:22 +0000
Current Price compared to previous values
View Count: 1163
| [2022-05-02 19:12:32] |
| User522009 - Posts: 1 |
Hi, I would like to know if it's possible to create something like that in SierraChart: Define time range for which current price will be compared. For example current price is 123$ and compare this value to latest 10 days using 1 minute interval. Result would be some kind of indicator presenting information that for current price=123$ 80% of previously defined range prices were lower or higher. Please let me know. I am considering buying the software and this feature would be really great to have. |
| [2022-05-02 19:58:53] |
All of this can be done. Refer to: Using the Basic Arithmetic Studies There is not a specific study to do this, but you may be able to use a combination of studies or certainly create a Custom study to do this or a Spreadsheet study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-02 19:59:08
