Date/Time: Tue, 11 Mar 2025 17:27:05 +0000
Two Support board threads without any difference
View Count: 418
[2022-05-02 17:49:01]
User613910 - Posts: 45
When I go to View my Posts / Threads I see two tabels:
1. Support Board - Threads by "User613910"
2. Support Board - Threads with Posts by "User613910"
I can not see any difference. Also how can I order them so I see the last sended message first when I open it and not one from 2019.
Also if you are not a frequent user of your support board it takes a lot of time and effort the find your way. Just for your infomration.
Thanks,
Anita
Date Time Of Last Edit: 2022-05-02 17:50:21
[2022-05-02 19:17:00]
Sierra Chart - Max - Posts: 5796
The 1st list is the list of threads that you have started.
The 2nd list is the list of threads that you have posted something, this will also include all the threads that you have started.
If you only posted in your own threads, then both lists would be the same.
You can click on the Arrows by "Date Time Created" to order based on the date time of the of the 1st post in the thread, or "Last Post Date Time" to order based on the date time of the last post.
Sierra Chart Support
