Date/Time: Sun, 08 Sep 2024 05:06:24 +0000
is there a quicker way to change Volume width size?
View Count: 498
[2022-05-02 15:58:48] |
User266069 - Posts: 30 |
i zoom in/out of charts a lot. Because the Volume indicator doesnt auto adjust width size when you zoom in/out chart, i am manually doing - right click > study setting > volume > Window - adjust width > ok - about a thousand times everyday wondering if there is a smarter way to do it, or a get around to make it less hasssle it would be incredible if SC could implement this so that a single right click to the region will bring up in the menu Width size 1-5 for selection, for just this indicator. Volume is the most common indicator and i feel like this QOL will benefit a lot of users. thank you Date Time Of Last Edit: 2022-05-02 16:10:03
[2022-05-02 16:57:29] |
User431178 - Posts: 495 |
Maybe this is not a solution for you and not exactly the answer to your question, but you can try setting the draw style for the volume subgraph to Fill Rectangle to Zero or Transparent Fill Rectangle to Zero, with either of these the volume bar always occupies the full bar width.
Date Time Of Last Edit: 2022-05-02 16:57:55
[2024-07-07 18:43:05] |
User624476 - Posts: 33 |
What the previous post said + add in a second volume study and set the drawstyle to Box Bottom Center (use a solid color to match your background), and the result actually looks like bars with a small space in between.
