Date/Time: Tue, 11 Mar 2025 17:42:17 +0000
value labels
View Count: 782
[2022-05-02 12:44:09] |
User633898 - Posts: 28 |
Hi, Is there a way to arrange the value labels set on the right hand side scale so that these labels do not overlap each other. Thanks |
[2022-05-02 16:54:51] |
John - SC Support - Posts: 38580 |
The only way to do this would be to expand the scaling far enough that each tick size is large enough for one label. But this would most likely make the visible area of the chart too small.
[2022-05-02 21:43:06] |
Borubar - Posts: 17 |
@User633898 You can add label column and split your labels between label column and right hand side scale: Label Column on Chart? Date Time Of Last Edit: 2022-05-02 21:44:17
