Date/Time: Tue, 11 Mar 2025 17:42:14 +0000
i would like my umbers bars chart to look like in the attached pic.
View Count: 483
[2022-05-02 12:23:53] |
Nicolae Bilc - Posts: 3 |
i would like my umbers bars chart to look like in the attached pic. how do i go about achieving that? |
![]() Attachment Deleted. |
[2022-05-02 16:53:27] |
John - SC Support - Posts: 38580 |
The only inputs we can tell for sure are the following: - Column 1 Numbers Bars Text: Bid Vol v Ask Vol - Open and Close Marker Style: Candlestick Outline - Place Open Marker/Boxes in: Column 1 Refer to the Inputs for Numbers Bars here: Numbers Bars: Input Settings for Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-03 07:20:54] |
I select open and close marker style as candlestick outline, but the chart still doesn't show the outline of the candle
[2022-05-03 07:27:00] |
Anyway, I have a custom template that I received from somebody. How do I apply that to a chart?
[2022-05-03 09:05:06] |
If it is a Study Collection, then refer to: How to Use an Advanced Custom Study or a Study Collection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
