Date/Time: Tue, 11 Mar 2025 18:06:02 +0000
poc extension lines until future intersection in sierra chart
View Count: 665
[2022-05-02 11:24:23] |
Benz - Posts: 46 |
Hi Guys, The poc extension lines until future intersection are not stopping at a future intersection and are going straight through the bars as per screenshot. I've searched for solution and cannot find. Please aadvise. Thanks very much. Benz |
![]() Attachment Deleted. |
[2022-05-02 16:49:13] |
John - SC Support - Posts: 38581 |
In the image at the bottom, the lines for the POC extension are showing correctly, but in the top image they are not. What is different between these two images?
[2022-05-02 16:53:23] |
Benz - Posts: 46 |
the top is a 5 tick reversal where i have the prob the bottom is a 3 min - other than that settings the same
[2022-05-02 17:03:12] |
Benz - Posts: 46 |
sorry John the bottom poc extensions arent working either - they are stopping on next bar when they are not intersected. thx
[2022-05-02 20:50:46] |
Please get us a chartbook with the charts that are not working correctly by following these instructions (only include multiple charts, not just 1): Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-03 07:56:21] |
Benz - Posts: 46 |
John thanks very much. I've found the problem. I had duplicated the number bars study which caused the conflict. I have removed the duplication and all is well. Sorry to waste your time. Please bear with me as a new user. Thanks for your help. |
